メインコンテンツにスキップ
Released 2012, model number L610 A point and shoot camera
8回答 すべてを表示
Why do I get a batteries exhausted error?
After using my camera for a period of time, it says battery exhausted on the screen and then turns off.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 35
6 件のコメント
I have the same problem.Bought FOUR new batteries.All have te same response.Grrr.
さんによる
i heard you need to use the same batteries as the ones you originally started out with when you got the camera.
さんによる
Every time I turn my camera on this happens. I put in fresh batteries and it will work for about 5 minutes and then shut off. However, if I tak ethe batteries out and flip them it will work for a minute or too. My camera has not been dropped or harmed in any way and is just over a year old.
さんによる
I sorted mine it needed alkaline batteries as there was no option for zinc batteries in the settings. Dont throw camera do this .4 yrs of crap now solved hurray
さんによる
Phillines615 I’m using “Alkaline” and the problem still Exists. I believe that something to do with the battery door. From my research this particular model cool pics L22 seems to have some sort of repetitive problem with the battery door compartment. Because every single battery that it says is exhausted, I have taken out and tested on my multimeter only to find out they are still brand spanking new!! In other words, before I place them in the camera they had a reading of 1.55 and afterwords they were at 1.55. I’m so frustrated I can hardly handle it!! UUUUUGGGGGGG!!!!!!!!!!
さんによる
1以上のコメントを表示
コメントを追加
18件の回答
最も参考になった回答
This error comes from either the camera getting to hot or the batteries being depleted. To relieve this issue let the device sit for a while. If the error persists after letting the device sit, replace the batteries.
Update
Checking the forums this seems to be a common error for this device but there is another reason this may happen. If the battery lid gets loose, the batteries are not held in tight. The extra space causes the batteries to arc which increases the heat inside of the camera. This issue maybe be relived by holding pressure on the side of the camera where the batteries compartment is. This pressure will create the correct contact that is needed for the device to work properly.
このアンサーは役に立ちましたか?
スコア 6
9 件のコメント:
i have replaced the battery but it shows same error
さんによる
With batteries? The main camera batteries or the batteries that you but in the bottom of the camera?
さんによる
I took a toothpick and jammed it between the bat and side of bat compartment and pushed it down and then I was able to charge. I believe it was a connection problem. A couple of layers of tape and it should fill the gap when closing the cover. nothing thicker than tape, something thicker may compromise the seal.
さんによる
Replace rechargeable batteries with alkaline and error disappears, then inserted back rechargeable batteries
さんによる
it is not the batteries or the way the batteries are installed or contact. it is a bad design, may software. chinese made junk @ @
さんによる
4件以上のコメントを表示
コメントを追加
Just read the correct answer, The order in which you plug the charger cable into the charger and then into the camera matters. ( when I read it I couldn't believe the order matters but it does) https://support.nikonusa.com/app/answers...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
My camera didnt come with a charger cord :/ I can only put batterys in there, but there is a place for the charger.
さんによる
This certain camera that it pictures at top and similar ones come with actual batteries, not rechargeable battery cards.
さんによる
コメントを追加
charge the battery for 6-8 hours and then you will not have this problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It may be because you left it on for a long period of time. Same with me.. I charged my battery for a little over 6 hours and it was fine.
さんによる
コメントを追加
Battery exhausted error occurs due to damage in battery door cap lock.Replace it and the problem is resolved
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have seemed to have solved the problem by using lithium batteries only
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I bought my Nikon Coolpix P5100
Yesterday. Naturally I charged it
overnight. My question why its say 'Battery is Exhausted". What is the cause and side effect? I'll appreciate if you
answer my questiona and kindly response on my concern. Thank you in advance for your immediately action.
さんによる
I do not the reason for the battery exhausted message. The side effect is the camera turns itself off and cannot be used. It makes no sense. All I know is using disposable lithium batteries caused the problem to go away.
さんによる
コメントを追加
Mine have the same problem. Im doing only 1 solution everytime the problem occurs.
1. Remove the battery for 5-10secs then put it back in.
2.Unplug the usb cord on the charger.
3. Then insert again the cord into the charger
4. Put the charger on the wall socket
5. Connect the charger in your camera
Then suddenly the charging indication light will appear :)
You just have to be patient everytime it fails, just keep on doing it several times.
I guarantee it will work and it will saves your money ;) DO NOT STOP UNTIL THE CHARGING LIGHT APPEARS. Goodluck!
Remember: PATIENCE IS A VIRTUE :)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you Celine. Tried this and it worked. :)
さんによる
I have a Nikon l24 and it says battery exhausted
さんによる
コメントを追加
NO NO NO NO NO...
To solve the "Batter Exhausted" problem, first open the battery compartment and check what type of battery you are using - Alkaline, Lithium etc.
Next switch on the camera and press menu button and then tools option (wrench).
In the list, find the "Battery Type". You should see some options:
Alkaline,
COOL PIX (Ni-MH)
Lithium
Select one of the above options corresponding to the type of battery you are using.
That should solve the problem.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The thing is, whenever I turn on my camera its gives me the error and just shuts off in 15 seconds.
さんによる
The battery type is the first thing to check. Especially if the camera shows suspicious value at battery level.
さんによる
コメントを追加
My wife had this problem which annoyed her so much that she stopped using it. I investigated and found out that in the battery settings there was no mode for standard zing batteries . I purchased some alkaline batteries and set mode to alkaline and they presto . She didnt use the camera for 7 years because of this lol. A simple thing that made a world of difference try before you do anything else .BATTERY
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Nothing to do with battery cover or charger or how made .it has no setting for zinc battery.if you still having trouble I'll have your cameras lol and I'll put some alkaline batteries in. Problem solved
さんによる
コメントを追加
I had this problem also. I read that if you charge the battery IN the camera it might cause this problem. I purchased a wall charger to charge my battery and I haven't had this problem since. It probably would help to get a new battery if yours is old. Overheating can cause the problem also. Good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The battery needs to be charged by using an external source, such as attaching the usb charging cord to your laptop. You can also take the battery out and charge it by itself, by placing it in the included battery wall charger.
さんによる
コメントを追加
Got the same problem with COOLPIX S2600. Solved the problem by charging the camera with the memory (SD) card removed. Advice: Do not use your camera when the battery is drained.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This only happens to me when I am used the video mode. I NEVER use rechargeable batteries, and the new batteries have the same problem. My guess is bad software or bad battery door. Door is a very cheap design.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Not bad software use alkaline batteries
さんによる
. . . . because the batteries WERE low. Old batteries , too long in the HOT garage and my "battery checker" was lying to me about the battery's charge. Use voltmeter to get a true state of new or used batteries.
さんによる
コメントを追加
Read this on Tom's guide.
''try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera.
this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.''
Actual Nikon fix
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I solved the problem by using alkaline batteries -Duracell brand. It wss driving me crazy -I kept getting the exhausted batteries sign and couldn't take photod, unless I replaced them every day or so. THE PROBLEM IS THE TYPE OF BATTERIES.
Use alkaline ones. It's worked for me.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
Thanks very much. That’s what I ended up doing too. It was a simple solution: ALKALINE batteries only!
さんによる
Who DOESN’T use Alkaline batteries??? LOL…
I’m using Alkaline batteries, and still same issue.
さんによる
Use lithium batteries. I do not get the battery exhaust message when using lithium batteries.
さんによる
What do you mean by lithium batteries?? Which model no. of lithium battery you are using now to resolve the battery exhaust problem? Because I am having the same problem using lithium ion battery EN-EL23.
さんによる
I am just using Energizer AA advanced lithium batteries. Haven't had the "exhausted battery" message since.
さんによる
2件以上のコメントを表示
コメントを追加
I had the battery exhausted error message when I tried to recharge my coolpix S7000
I found using the supplied plug and cable resulted in the battery being depleted.
i tried a different usb cable plugged into an Anker multi point charger worked
hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if you look on battery label it says 3.0 to 2.4 dc v b1.4 to 1.9 a if you test battery with multi meter and your battery is 1.55 and other is 1.55 add both together your over by .10 so make sure battery voltage says 1.2 v on battery that way you should be in 2.4 v to 3 v top and if that don't work in many cameras there is a small battery that powers display time memory and charge might need to be replace c heck online youtube you will see what i mean
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
this procedure worked for me:
  1. Turn on your camera and press the Menu
  2. Navigate to the Setup section and choose Battery type from the menu.
  3. Now select the appropriate battery type that you’re using and press the OK
  4. After doing that, the issue should be resolved.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i Think you need change pin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
take off the SD card and charge your camera normally !!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeremy さん、ありがとうございました!
統計データ:
過去 24時間: 61
過去 7 日: 387
過去 30 日: 1,809
今までの合計 111,287
