Why my lenovo vibe x s960 camera cannot open?
camera lenovo vibe x s960 problem
GO to settings - apps - find camera app and clear the data and default and cache
このアンサーは役に立ちましたか?
But there's no recorded to my default that's why I can't clear it..
My front cam. Is not working please help me..
heyitsmejra,
i believe your are experiencing hardware fault. remove and reinstall the camera module and check whether it working otherwise you may have to replace a new camera module
may i know how to reinstall the camera? i also having same problem, suddenly the camera unable to connect. help me pls.
Help me please... Me already do all of that , and already update the system, still can't use camera help me
Rixson Frack, You may have to replace the camera
My front camera of Lenovo vibe x doesn't work, i want to know if there is any way to fix it or enable it
このアンサーは役に立ちましたか?
me too. have your front camera been fix??
Unable to connect to the camera
Uunable to connect to the camera
このアンサーは役に立ちましたか?
I also have 'Cant connect to camera' on my S960, and I tried different software things with cache, another camera app install, etc. Nothing solved the problem. After that, I've done full software reset to the factory settings. That also didn't help. After a month or so, when I decided to go to the service, I tried full reset again, and my camera problem dissappear!! Now it's working perfectly, and my phone battery last longer than before (I don't know is this related with camera..)
このアンサーは役に立ちましたか?
How did you full reset???
I mean factory reset.
このアンサーは役に立ちましたか?
factory kit test
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 5,163
1件のコメント
what this is factory kit help
Bharat Agencies さんによる
