My gateway laptop is not connecting to wireless internet
i think my wireless card is broken .its not working but my wired internet is not working . please help ?
should i replace my wireless card ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
hello,
there should be a sliding switch on the very side or back of it, bottom part with keyboard, check to make sure its in the on position. If it is, try looking for a Reset Wifi driver on gateways website, it would be able to set the "wall" of wifi back up.
このアンサーは役に立ちましたか?
just try following steps that might help -
just reset the adapter settings in wireless device and update the wireless driver and make sure time and date is also correct in computer . also check the wireless password and for more visit gateway websites help section and see if this works for you . let me know if you need anymore help
このアンサーは役に立ちましたか?
I was told locally that this is an endemic problem and can't be repaired. Can a used computer be scavenged for the bad part.?
このアンサーは役に立ちましたか?
My laptop won't work either wired or wi fi. If it is just the io card can that be replaced?
過去 24時間: 2
過去 7 日: 11
過去 30 日: 52
今までの合計 6,122
