メインコンテンツにスキップ
The GEAR’D UP RC Ford Mustang GT is a remote controlled car released in 2014 and is sold by Jam'n Products INC. Its Amazon Standard Identification Number (ASIN) is B00NE4NTYS. A similar car exists with the same design, but the other car is marked with police colors instead rather than the red and white colors that this model has.
How do I access the batteries in the car?
Do I need to remove the car shell, or can the compartment be found underneath the car?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
The batteries in the car are located between the two rear wheels on the car. They are covered by a plastic casing, which is held on by a screw. The screw can be unscrewed using a Phillips PH0 screwdriver and turning it counterclockwise.
For step by step instructions, please refer to the Car Batteries Replacement guide.
When you replace the batteries, be sure to insert them in the correct orientation or your car will not turn on again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Matthew Seno さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 226
