MBP's 3TR Airport card in 2TR MBA. Which antenna should I add?
Hi.
I just swapped Airport card on my MBA, from original MacBook Air 2013 2 antenna 11ac to MacBook Pro Retina 2014 3 antenna 11ac.
It has different length(MBP's are longer) but fit enough to work. Actually it works. And I made just-work-anyway-but-cannot-install-inside-laptop-cause-it-is-1-feet-size iron wire antenna, 1 inch far from router, it shows 1.3Gbps. Test done.
Problem is, MBA has only 2 inside antenna. So I have to make or buy third antenna, which small and thin enough to install.
Does anybody did this job with good antenna rate? What antenna should I use? Is there general products? Or should I make DIY?
この質問は役に立ちましたか?
