How do I get my speaker to turn on?
I am having issues with the power function of my HMDX Jam speaker.
1. make sure your speaker is using the right micro USB cord and its connected to a power source (computer, universal USB charger).And leave it on the Charger for at least 3 to 4 hour.
2. If your still having issue with your HMDX Jam HX-P230 , you can reset the speaker by pressing and holding play/pause for 5 seconds until you hear a noise. And repeat step 1.
3. For further help, call HMDX Jam customer service team at 1-888-802-0040 for technical issue.
このアンサーは役に立ちましたか?
Thank you SO much! I cannot believe it - bought this HMDX "Daze" Bluetooth speaker on clearance at Target like 8 months ago & it stopped charging. I called the # given above and they are mailing me a brand new one - no questions asked! Thanks again
Hey man I have your solution! Same thing happened to me and I looked up the customer service # for the manufacturer (HMDX or whatever) and there must be a known defect as they sent me a brand new one - no questions asked!
このアンサーは役に立ちましたか?
Hi @ Rhonda Easley,
Here’s a link to the user manual for the speaker showing the Volume Controls etc.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 15
過去 30 日: 56
今までの合計 38,685
8 件のコメント
Should it be turned of while charging cause the charging ligth only turn on while it on
Lollipop さんによる
Why does my jam box that is brand new, not turn on when i know I have turned it off previously and its definitely got full charge? Winding me right up dont know if im doing something wrong or its faulty. Please help!!!!!!
Clare 123 さんによる
I cant get it to work anymore on laptop, i-phone etc... I have charged 4+ hours what can I be doing wrong it used to work great!!! & I have all original pieces.
Darlene Paterson さんによる
Guess the power light stays on the unit does not work
Marcus Mitchell さんによる
Help
My red light is on and nothing else works
3件以上のコメントを表示
