メインコンテンツにスキップ
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
20回答 すべてを表示
How to change my tablet charching port.
because, when i try to charcge it it won't work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
2件の回答
最も参考になった回答
There is a possibility that it may not be the charging port, but a bad battery. If it is the battery, you have to replace it with a new one. Please use our guide on how to replace the battery:
Asus MeMO Pad HD 7 Battery Replacement
If it is the charging port that is defective, you must follow our guide on how to detach the motherboard:
Asus MeMO Pad HD 7 Motherboard Replacement
Once you remove the motherboard, you are going to have to remove the solder at the four soldering points that keeps the charging port in contact with the motherboard. With your new charging port, you must solder it using the four soldering points on the motherboard.
If you do not want to solder the charging port off and solder a new one in its place, we recommend buying a whole new motherboard. Luckily, we sell the motherboard on iFixit:
ASUS MeMO Pad HD 7 Motherboard
Main circuit board assemblyの画像
製品
$29.99
Asus MeMO Pad HD 7 Batteryの画像
ガイド
難易度:
簡単
15 minutes
Asus MeMO Pad HD 7 Motherboardの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Related to this answer/scenario, would replacing the whole motherboard be equivalent to resetting the tablet? In other words, is the device memory included on the board such that replacing it would be a clean slate? Thanks!
さんによる
Yes it is, it's basically like getting a brand new tablet so you will need to reinstall all of your apps and you will lose anything that you haven't backed up. Anything saved to your memory card will be fine as you can just swap that across.
さんによる
コメントを追加
The the charging port need replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ivan Rafael Ramirez Romero さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 10,532
