Why can I not record video?
I press record, and the video is not recording. There is no error message saying I have limited available space because I have an empty 16 GB SD Card.
Your camera is encountering either an error or a connection problem. An error may be remedied by checking the manual for software troubleshooting or checking the Olympus website for tech support. However, if it is not a glitch, then the connection between the SD card input pins and the circuit board may be messed up. Please check the repair guide to see if you can access the SD card slot connections.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
