メインコンテンツにスキップ
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2回答 すべてを表示
締切られた回答
How do I get my pump to stop making bubbles?
My pump works but it makes bubbles.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This is most likely due to a broken impeller, and the impeller assembly will need to be replaced. It could also be due to air locked in the pump housing, which is most likely due to the pump not be fully submersed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 630
