メインコンテンツにスキップ
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2回答 すべてを表示
締切られた回答
Why is my pump making a strange noise?
I have a pond pump that started making a high pitch noise. Any suggestions on how to make it stop?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The noise is most likely an indication that the motor has failed. It will need to be replaced, along with the impeller assembly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 437
