メインコンテンツにスキップ
Released March 2012. Lenovo IdeaTab Model S2109A-F running Android 4.0. Model name:2291
2回答 すべてを表示
締切られた回答
Why does my Lenovo tablet die so quickly?
I have recently noticed that when I use my tablet it tends to die a lot quicker than when I first got it. I have tried decreasing the amount of apps I use on it and changed the settings for it to be more battery efficient, like turning off wifi when not using it, but the battery still drains quickly. When I plug it into the power adapter it will stay on and charge, but as soon as I unplug it, it starts to drain quickly again. What is going on with it and how should I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Your Lenovo IdeaTab S2109A-F may have a faulty battery. Since you plugged it in to the charger and it stayed on that eliminates the possibility of a broken power adapter. You can replace the battery in your IdeaTab with minimal effort by following the Battery replacement guide found under Faulty battery on the Lenovo IdeaTab S2109A-F troubleshooting page.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 878
