メインコンテンツにスキップ
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
shorten heigth of poles
have a halogen floor lamp. someone shortened it now i need to add pole back in for height.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You should be able to get replacement pieces for the pole (depending on how thick the pole is or if there are any decorative aspects) from any home improvement store. Home Depot, Lowe's, Rona. You will have to check to see if you have enough power cord available for the extension though. Fixing something like this is not for the faint of heart so if you are unsure ask someone in the lighting dept on tools you will need etc.
Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
shermoonlight62 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,320
