メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2376回答 すべてを表示
How to fix a dark screen
Hello,
My phone got wet, after drying it with rice and using a tooth brush with an alcohol solution, I replaced my screen and my battery. The phone is fully functional (including the touch) except there is no light on the screen which is completely black. Any advice?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Amit, rice is great for Gallo pinto :-), but it will not fix your phone. Rice does not prevent corrosion, it is the equivalent of doing nothing. The very first thing to do is to disassemble your phone. Use this guide. Once you have it disassembled clean it with +90% isopropyl alcohol. Do not substitute this with other cleaners :-) Use this guide to see how to clean the phone. It was written for a 3G but all the steps are pertinent to your phone as well. Check for any missing or charred looking components. Once you have it cleaned, replace the battery and reassemble your phone. Reevaluate for any damage.There is really no a surefire way to say which part is the one that gives you the problem. I would recommend that you start it systematically. Make sure that your replacement screen really works. If it does, take a close look at the backlight IC and coil on the logic board. That repair is a bit more difficult due to the fact that those are SMD components. Water damage is the hardest to diagnose and to repair since you never know exactly which part has failed. Even if you do everything right, there is still a good chance that your phone will never be the same. Hope this helps, good luck.
iPhone 4 ロジックボードの画像
ガイド
iPhone 4 のロジックボードの交換
難易度:
難しい
30 minutes - 2 hours
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
The screen is new and working with another phone and the battery is also new. I also cleaned the corusion which leads me to believe it's the coil, backlight IC or both. Thank you very much for helping me figure this out but I'm afraud this is out of my league. How much would you expect this would cost if I will go to a shop to get it done?
さんによる
You're from the USA? I found this offer on eBay: http://www.ebay.com/itm/iPhone-4-iPhone-...
さんによる
UK, I am sending my phone to a similar place here, thanks.
さんによる
コメントを追加
最も参考になった回答
Hey, you cleaned the hole logicboard with >90% Isopropanol? I'm not sure but I think there is a chip on the logicboard, which controls the backlight. If you have bad luck, the chip is faulty.
You bought a new screen, can you verify that the screen is really working? Maybe you got an faulty screen.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Amit さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 91
