メインコンテンツにスキップ
Repair and disassembly information for amplifiers in home audio systems.
117回答 すべてを表示
Right speaker terminals have no signal. Possible to fix?
Hello guys,
I wanted to use this old amplifier, a Kenwood KA-56.
But unfortunately for both outputs (speakers A and B) only the left connector receives a signal.
Somewhere the signal to the right terminal is lost.
I know i is not expensive to buy a new one, but I wanted to have an idea first about the option to fix this myself.
what do you think?
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
Chances are you have a output transistor that has went out. These devices are in place to provide sound in the speakers through a chain of other components. These devices are a common failure when it comes to our now called “ through away society”. It will need to be looked at and diagnosed by a professional tech. This is something you may not be able to do yourself for reason of LETHAL HIGH VOLTAGES and lack of equipment and or knowledge.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i have the same problem acspt my center speaker is not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Top さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 28
今までの合計 1,796
