No sound or distorted sound out of headphones
When I play a audio file on my computer no sound comes out of the headphones.
Try your headphones in a different computer, that way you can test whether or not it is your headphones that are malfunctioning. If you can, also try and verify the sound file (corrupted files can have distorted audio). If neither of those solve the issue, try to update your audio drivers. If your issue is still not fixed, you may have a damaged audio port or sound card. However, because both of these components are integrated onto the motherboard the entire motherboard will need to be replaced.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 161
