headphone jack on acer chromebook only plays right side.
Can someone post a guide on how to replace headphone jack on Acer c7 Chromebook? I can only get left left to work.
I suggest replacing it. Although, I have tried angling the plug and it works provided you keep it there. Also, a risky way of fixing it is if you stick a needle into the jack itself and push some of the conductors outward towards the hole. It'll either fix it or make it worse.
このアンサーは役に立ちましたか?
Are they headphones from Apple? They don't work
このアンサーは役に立ちましたか?
I have the same issue and it happens with apple products and other devices
過去 24時間: 0
過去 7 日: 6
過去 30 日: 9
今までの合計 1,567
