メインコンテンツにスキップ
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
455回答 すべてを表示
Demo unit only powers on when plugged in.
My demo unit only powers on when the power cable is plugged in. It automatically powers on, but it shuts off as soon as I remove the cable. When I switch it off, it comes on again after two seconds. Battery charges normally until it's full. I checked the battery voltage, everything is normal. I tried with another battery - same problem, so it's not the battery what's causing this.
I guess Nintendo made some kind of modification to the mainboard. Maybe a jumper, maybe a chip that needs to be replaced, I have no clue.
I know that there are people out there with the same problem and I would really appreciate if someone knows how to fix it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
demo units have a fuse removed to deter theft. that model will always only work on the charger, however, if you buy a new motherboard I believe that fixes the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Fabi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 224
