メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
power button shorts out phone
iPhone 4s was stuck in recovery mode, eventually got it out of recovery, but was then in 10x boot loop. I unplugged the screen to see if it was a faulty replacement screen. still recognized in iTunes, but still boot loop. tried to hold volume up. still wouldn't boot. I unplugge the Lock Button connector and the phone successfully restored and started. if I plug the lock button in while the phone is on, I can use it for 1.5 seconds, the phone will shut off. it will then continue to TRY to reboot. does anyone have any idea why this would happen? it is NOT water damaged.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It's usually water damage. Even so slightly. I suggest replacing the flex. This should solve it. When you take out the flex inspect it I can almost guarantee there's some corrosion on it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 47
