メインコンテンツにスキップ
Repair information and troubleshooting for the Dell Latitude E6230 business class laptop computer. This laptop has a 12.5 inch screen, and was announced in May 2012.
15回答 すべてを表示
Laptop freezes after waking from hibernation or sleep?
for the past few days, when i wake up my computer from sleep and hibernation mode it'll freeze and the only way tp get it to work is to hold the power button.
just for your information, i recently updated some drivers but i will try to delete the new power management driver and go back to the old one
Edit: i cannot roll down battery driver for some reason
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 43
75 件のコメント
Brothers , just go to
1. "Device Manager"
2. "Storage controllers"
3 . Right click on "O2Micro Integrated MMC/SD controller" and disable this driver.
Your Welcome!
さんによる
Thanks alot brother (Y)
さんによる
I was having the same issues with my Dell latitude 5420... But with the steps above I was able to stop it... Thanks Alot...
さんによる
me too, same issue with Latitude E6430 and the above steps solve it. Thank u very much
さんによる
Wow...Thank U Thank U it worked for me
さんによる
70件以上のコメントを表示
コメントを追加
6件の回答
最も参考になった回答
It's one of the card readers, just disabling it fixed the issue for me
このアンサーは役に立ちましたか?
スコア 9
9 件のコメント:
what is the card reader?
さんによる
thanks much bro... you made my day and I have solved the problem which bothered me almost two months ..I changed the window almost thrice times but the problem still existed till today i got ur help...thanks much...
さんによる
1. "Device Manager"
Your Welcome!
さんによる
Thnx bro, worked for me also
さんによる
Thanks a lot bro i too resolved by this problem
さんによる
4件以上のコメントを表示
コメントを追加
1. "Device Manager"
Your Welcome!
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Zabihullah Xabih  thank you. In my computer I have not option “O2Micro Integrated MMC/SD controller”, but I check another similar things. In my computer (M4800) the problem is option “ ControlVault decive”. Click on it and choose “Disable”. And computer works perfectly (without freezes after waking). Thank You! You helped me to find solution! :)
さんによる
Even I changed the OS from Windows to Ubuntu and CentOS but still I’m getting the same issue and many of the users are complaining the same thing on Dell E7490. It seems some hardware issue not OS issue If we lock (Win+L) the system It's happening Hence, we are turning of the monitor instead of it. Any solutions would be appreciated. Thanks in advance!
さんによる
コメントを追加
Same issue here (caused by the Dell O2 card reader driver A04).
Edit: the A02 revision of the above driver causes the same issue.
This issue occurs in Windows 7, 8, and 10.
I fixed it by uninstalling the Dell O2 card reader driver Rev A04 and then installing the Lenovo equivalent driver from here:
http://support.lenovo.com/gb/en/download...
This covers Dell Models
E5530
E6430
E6530
And probably any other Dell laptops with the O2 card reader driver.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This is indeed an O2 Micro driver problem. Delete it from Device Manager. It will ask if you want to delete drivers, and say yes. Rescan for hardware change, and let Windows 10 install default SD card reader drivers. This will allow you to still use the SD card reader and put the laptop to sleep without issues.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Reinstall OS it help me with freezing while going to sleep
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my lap top starting windho hang auto off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
V_S さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 8
今までの合計 51,790
