メインコンテンツにスキップ
Samsung製のラップトップ用修理ガイド
346回答 すべてを表示
Samsung ATIV book 9 lite micro hdmi port problem
When I put the cable in the lcd tv and plug the micro hdmi at my ativ book 9 lite nothing happens the notebook does not recognize my external tv or projetor via micro hdmi. How can I solve this? Is there any micro hdmi drivet needed to be installed or does the micro hdmi port needs to be activated somehow? Please help me
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
I have this same problem. I found a similar problem on a Lenovo Yoga board and they solved it by shaving part of of the plastic off of the plug, about a millimeter. It is not a 100% fix for the Samsung because you still have to angle the plug up to make the connection work and it is loose, but it does work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello,
i have a problem with connecting my samsung ativ notebook to my external monitor with HDMI (micro).
This problem has occured since a week. I bought the laptop with windows 8, but currently using windows 10 (since 6 months).
It seems to be a driver issue... with the Radeon HD 8250 AMD.
Device manager says that there is a problem with graphic drivers.....Microsoft Basic Display Adapter (No ACPI support). I tried to delete it, but after that it still did not work.
Does anyone have any idea?
Please help me!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not sure if this helps but I have an ATIV book 9 lite with win 10 and the hdmi works fine
I did use drivethelife to update all of my drivers after installing win 10, don't know if that made any difference
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Unplug the HDMI cable - Go to "Device Manager" - "Dispaly Adapters" - "Intel Graphics" - Click the Driver option - Roll Back Driver (to whatever previous version) - then Update Driver again - Restart Computer and plug the HDMI back to test if it works.
Do this couple of times if it does not work at the first trial.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have same problem with my N905s3g , I use the micro hdmi to vga , the laptop recognize the external monitor and works beautiful for couple of minutes. then the monitor goes to black, I have to unplug the cable , and plug the cable again to get monitor ,but it lost again after couple of minites
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Someone else having a loose microHDMI and charge connector? Happened on all our Samsung laptops, getting glitched problems.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes I have. They wear out and the micro HD​mi is of poor quality. On my 4th adapter. Im going to buy a good quality adapter but micro to hdmi is hard to find
さんによる
コメントを追加
回答を追加する
Meg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 6,125
