メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
display brightness not increasing or decreasing
I have a samsung galaxy s3 i9300. Its screen got cracked so gave it to a local repairer.he replaced the whole display and touch.the touch is working fine but now the display brightness is neither increasing nor decreasing. So my question is.is there any problem in display?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 12
1件のコメント
sir mera samsung j5 ki brightness work nehi kar rahi ha ji kya karu ma plz.. mare problem ko solve karo ji
さんによる
コメントを追加
10件の回答
最も参考になった回答
The replacement screen u got is an lcd whereas the original one is an led.thats why the brightness cannot be controlled
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
but there aren't a solutions for brightness check with an led display?
さんによる
I would have believed this until I used a 3rd party app to check control brightness, that worked perfectly fine. I would try a phone reset but right now using the app.
さんによる
コメントを追加
Hi Nitish,
Are you sure auto-brightness is not activated?
Perhaps energy saving is enabled?
To test everything with your screen i suggest you launch the test menu and see if everything works there, there is a special button called "dimming" there to test as such;
-> go to your "keypad" (as if you want to call somebody)
-> Type in: *#0*#
It should start the test menu instantly.
Let us know what the tests do :)
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
In dimming test it showing three colours. Red,blue and green. Nothing else is happening
さんによる
コメントを追加
go to play stor install apk name NIGHT MODE it can be easly fixed
ukrain rx
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If you have replaced your display folder then sometimes you face this problem , because of cheap quality display folder .
For this you have to download night mode application from play store .It will work for you.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Reset your device and off the auto power saving and try again
I think its work unless there is a hardware problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you have changed your phone display then it might create problem because some china display doesn't have the hardware that support display brightness. If not so then try factory data reset this might work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes bro u are right? This happens to me also,it is only because shop owner replace not the original folder infact any third class , cheaper folder?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My mobile brightness not increase problem samsung j7
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
First check the auto brightness option,This is the symbol of copy Lcd only to display the graphic not controlled light system and phone also goes to heating up problem better to change original OLED LCD.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
brightness not working samung c7000
Update (09/17/2019)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
nitish tokas さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 27
今までの合計 43,351
