メインコンテンツにスキップ
モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 プロセッサ
330回答 すべてを表示
Everything is huge, No resolution sizes on iMac
I just finished replacing my cracked imac late 2012 screen. The computer posts but everything is huge and pixelized. When I get to display under system pref, there are no resolutions under scaled. I have no idea whats going on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
I just restarted and now it wont even turn on.
さんによる
I got it to turn on again. The screen works when its woken out of sleep, but everything is still 640x480 and my monitor is detected as: 'spdisplays_display'
さんによる
Another update. After another boot the monitor looks like its off, but when I flash a light on the screen at a certain angle I can see my desktop, which leads me to believe the backlighting isnt working on the screen, but that doesnt explain why there are no resolutions
さんによる
This may be a warranty issue, please give us the last four figures of your serial number located on the bottom of your stand or in "about this Mac", under Hardware if it will boot to a viewable screen.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Maybe you missed this when I posted it as a comment:
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
DNCW are the last four figures of the serial
さんによる
Apple iMac "Core i5" 3.2 27-Inch (Late 2012) Specs
Identifiers: Late 2012 - MD096LL/A - iMac13,2 - A1419 - 2546
さんによる
Look on the bottom of the stand to see if you have a AMD Radeon HD 6970M video card.
さんによる
I doesnt say anything about AMD on the bottom of the stand
さんによる
コメントを追加
1. Choose Apple menu > System Preferences, then click Displays.
2. Click Display, click Scaled, then select a resolution. Some apps may not fit entirely on the screen in some scaled resolutions.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
"no resolutions under scaled"
さんによる
コメントを追加
That looks like a driver issue. Either you need to install some drivers for that new screen, or your gpu has failed and your computer is using your logicboard to output video.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The backlight on LCD isnt working
さんによる
コメントを追加
回答を追加する
Robert Barnwell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 403
