S4 i545 Antenna 4G LTE
Is there any way I can get a different type of cable that will fit the red antenna cable on my Galaxy, since they are out of stock and I need one asap!
Unless you are good at altering this type of cable to expose the ground braid at the certain point that it hits the frame it would have to be ordered. There is a section of that RF cable that hits a plate within the side of the frame, which underneath, most likely, goes around the frame. I believe this is the WI-FI antenna.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 466
