メインコンテンツにスキップ
1997年にラップトップコンピューター市場に参入したAcer。同時にTexas InstrumentsのモバイルPC部門を買収しました。
1682回答 すべてを表示
Why do I keep losing internet connection?
I keep losing internet at random and have to restart to get it back.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
i can tell you these steps and this may help -
check the latest driver for wireless card and make sure its updated
remove the check box from power management that can turn of the power of wireless card . and see if that works for more visit acer https://goo.gl/h3VKKF and i am sure this will help to get your system work fine again . thanks
さんによる
Then try rebooting both your laptop and the cable modem (unplug it, wait 10 seconds, then plug it back in). If your Internet connection returns anytime during this process, it's possible the problem is with one of the components of your home network (router, wireless access point, etc.
Switch to AT&T Internet it is fast and 99% reliable even during peak hours.
The plan starts from $50 to $90/Month if higher the plans are higher the speed.
ATT Internet key features and benefits:
Connect across ATT’s 30,000+ hotspots nationwide and save your data.
Smart Home Manager App to manage your home Wi-Fi network.
ATT Internet Security Suite powered by McAfee at no cost.
Please visit website for more details @ https://www.att-uverse-internet.com/
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi Rowdy,
Could you give us some more information please?
What do you mean with losing internet and having to restart, does it drop the signal making you have to reconnect to it or does it completely dissapear saying there is no adapter/connection available?
Also, what type of laptop do you have? (Model nr)
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
its an acer aspire. i would get diagnostic policy service not running and i tried to restart it and it will work for a little while then i lose internet connection right in the middle of watching video or surfing google,but still have full strength on my wifi. just keeps saying waiting for google or whatever site im on.
さんによる
* Try this:
Go to start.
Type in search: CMD
Rightclick the CMD.exe comming up, and execute it as administrator.
Type the following:
net localgroup Administrators /add networkservice Press enter and type the following:
net localgroup Administrators /add localservice Press enter and type the following:
exit
Press enter and restart your laptop.
If this does not fix it let me know and we can try some other tweaks. If it does solve your problem please accept the answer so others with the same problem are helped out aswell.
さんによる
i tried that before and didnt work for me. i suspect it may be my internet explorer and have since downloaded chrome and havent had the issue since. if i continue to have the problem ill let you know. thank you for your help!
さんによる
The angle of the display affected my WiFi connection. At 90 degrees WiFi was fast but if I pushed the screen all the way to 110 degrees (fully open) WiFi was extremely slow. I think it affected the connection to an antenna in the screen.
さんによる
I have tried this and updated drivers..still have the same problem. I started getting this problem when I changed service provider. But my other computers (Macbook pro and imac) have no problem connecting and staying connected.
さんによる
コメントを追加
My internet connection goes for 20 seconds every 3-4 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i have an Acer Aspire R13, it keep dropping Wifi connection. have to restart and wait few minutes before getting connection. when i get to a different hot spot i have to restart before getting connection.
the less modern old laptop i have are all connecting nicely on the same hotspots and home wifi
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Just go on Amazon and grab another newer wifi card for less than $20. Or try to see if there are updates for the wifi available.
さんによる
コメントを追加
The R13 is a pile of junk. No other device disconnects like this thing - cheesed off with it!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mrrowdy18 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 19
今までの合計 19,060
