メインコンテンツにスキップ
iPad Air Wi-Fi +セルラーモデル、モデル番号はA1475でスペースグレイかシルバーのカラーが選べ、容量は16/32/64/128 GBがあります。
125回答 すべてを表示
iPad Air behaving erratically: "ghost touching" after screen replacement?
Usually, but not always, the replaced screen starts to behave erratically a while after installation. Immediately after screen replacement it works fine, but during the same day it starts to have these "ghosting" problems. The funny thing is that not every screen have this problem. I have been wondering what can cause this problem. Does the adhesive "let go"? Two screws at the top of the screen has a black protection sticker. I have tried to skip them and to keep them but still it doesn't help. I have tried to be really precise when I remove the old adhesive from the frame. I have also tried a "so called solution" to tape the digitizer copperframe, still no good. I also use the old home button. Are my replacement screens bad quality or am I doing something wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
solution to phantom/ghost touches ipad air
The following link is a fellow user of Ifixit who posted how to fix this issue.
If this has helped please score the fellow ifixit user and accept my answer.
Update
Unfortuantly i couldnt find anything, apart that when the screen was replaced, it may have affected some hardware/components.
If you have warranty take it to your apple store. If you have repaired it yourself the warranty is now void.
My solution to this would be a new screen replacement from apple themselves.
If this has helped please accept this answer
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The tape solution doesn't help.
さんによる
okay, give me a couple of minutes when i look for a solution
さんによる
コメントを追加
I hate the iPad air repair because of this ghosting problem! Even with the tape some iPads still have this problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Ok a Repairer in this forum said that tape should be applied to the ribbon and the wires.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Adidan,
Usually the taping needs to be done on the iPad mini. On the iPad Air it is faulty replacement screens. I have had 3 in a row sometimes, you can imagine how frustrating that is.
You can put the screen down before adhering and gently push around the edges without cracking the screen to see if there is any one area that triggers it.
Try and put on the old screen if it isn't damaged to much and see if it still is "ghosting".
If you have another iPad Air for testing you can test the replacement screens to see if they "ghost" on another device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
adidan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 35
過去 30 日: 154
今までの合計 9,335
