メインコンテンツにスキップ
グーグル5番目のネクサスフォン。2013年10月31日に正式発表され、4.95インチ1080pディスプレイ、2.26GHz Snapdragonプロセッサ、LTEをサポート。Android 4.4.2、KITKATを搭載。製造はLG。
222回答 すべてを表示
My Nexus 5 has water damage apparently. Can it be repaired?
I am in Brazil for the foreseeable future and have managed to break my phone... and prices are very steep here to just go buy another one!
I took it to a repair shop in a local favela... my friend knew the owner and so I could trust him with my device. When I went to pick it up he said that the 'placa' had begun to corrode due to water exposure... which I believe is something like a motherboard.
I am not sure how any water got in to the device... I have had it for about 6 months and not once have I dropped it in a puddle or taken it out in the rain etc.
It started acting strange..lagging up and resetting itself. Then it started resetting itself constantly just getting to the Google logo and then resetting again without any way to stop it.
Now, I believe the battery has just died so it is just a paper weight at the moment.
Any suggestions? Can I buy spare parts? Or should I sell for 70 reias (basically 25 dollars)?
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Open the phone and clean with 99%+ iso alcohol, check components for corrosion and replace if necessary.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Can I use Isopropyl alcohol to clean out the LCD screen? I cleaned out the circuit boards but there seems to be water stuck inside the screen which is making it darker.
さんによる
コメントを追加
Yes it can be repaired I my self had taken mine all apart ,piece by piece let it dry, but I also did shut it off quickly as possibleofcourse and cleaned it with rubbing alcohol. I put it back together turned it on and it was working even better I thought lol.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 3,062
