メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
iPhone Not Turning On, But Is Recognised In ITUNES?
My iPhone has stopped working. I cant turn it on, but is recognized in iTunes.
I have Tried Holding the Lock & Home button together to reset, to not avail.
Nothing is showing on the screen. its not vibrating either so its not the screen.
HELP!! I DON'T HAVE AND WARRANTY LEFT AND NEED THIS FIXED
THANKS IN ADVANCE FOR ANY INPUT
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
If the phone is still receiving messages/calls etc and is turned on then you need to check the lcd connection and replace if necessary
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
If nothing is showing on the screen, the screen may be damaged, or the LCD flex cable has come loose from the logic board. The first step I would try is to disconnect the battery for a few seconds and then reconnect it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have Disconnected the battery for about a minute. But no change. Even if the screen is damaged, the Phone would still vibrate. switching it from mute to normal would also make it vibrate
さんによる
コメントを追加
After checking all the flex cables to be fully seated and make good connection I would try to put on a new screen assembly and see if that fix the problem.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Ok, i have just tried a NEW Screen but still nothing. I just had a thought about the Power/Lock Button maybe not working?
Is there anyway to bypass pressing it, like you can with the home button? (But surely when i charge the phone, it should turn on, and i would see it charging, so maybe not. Any other ideas?
さんによる
FIXED: With a new Screen fitted, i then held the POWER button & Shorted the HOME BUTTON TERMINALS Internally. This reset the phone. It not turns on and works fine. Just need to get a replacement Home Button Ribbon. Job Done.
THANKS FOR ALL YOUR HELP!!
さんによる
コメントを追加
i think it is in recovery mode..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Graham さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 5
今までの合計 2,364
