メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
20回答 すべてを表示
My iPad won't charge. What should I do?
My iPad won't charge. What should I do? I tried using different iPad Chargers and Cables but it doesn't do anything. I also tried plugging it onto the PC but it doesn't react as well.
I tried turning it off, then plugging the charger in and like what its supposed to do, it turns on! I don't know what to do now that I'm reaching 10% battery. Turned off wifi and turned the brightness on the lowest. I hope i get an answer before it dies off.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 15
1件のコメント
I need more battery!! I need 2000&
さんによる
コメントを追加
4件の回答
ベストアンサー
If you are using a known good (original) cable and a known good wall charger, and still it doesn'tt charge properly, then there are many other reasons why your iPad is not charging, and you need to open it up to find out why. You need to follow the path of current to see where it is broken:
1/ The charging dock is defective and not passing the current like it should;
2/ The charging dock is fine but due to a fall, it moved and needs to be reseated on the board;
3/ The path is partially broken on the logic board which is malfunctioning. You will need the help of a trained technician to troubleshoot and repair this one;
4/ The battery bank is not holding a charge like it should. One good way to tell is if one or more of the batteries is swollen. But it could be defective and not swollen.
Not to sound discouraging, but to open the iPad and test all those, you may need a new dock connector and a new battery, and still may have not solved the issue. Plus you might break the front panel during disassembly.
If you feel up to it financially, and have the time to do it, let us know and we can guide you through the needed steps to minimize unneeded expenses and maximize chances of locating the fault. Or you can take it to a reputed repair shop and have it diagnosed first.
You can read through this guide to see what you will be up to if you decide to try the repair yourself.
このアンサーは役に立ちましたか?
スコア 7
コメントを追加
I've been having this problem too, but mine died and just has an endless loop! I NEED HELP
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
== Escape to your own dream island! Join as my Beach Buddy and play #FVTropicEscape for free.
https://5rfu.app.link/CLQ9YRBcbD'''bold text''' ==
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
  • Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
vincentdlsvds さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 27,446
