Why is my phone not turning on?
Every time I turn on my phone, it opens for a few seconds then it turns off again, vibrating constantly. I tried charging it but the results are still the same. Help!
Hello,
When you say that "it opens for a few seconds," do you mean that the phone boots up but not completely? To what point does it boot before resetting? The constant vibration is usually a sign of a bad battery. How long has it been since the battery has been replaced? A replacement battery is cheap and the quickest test you can do, so start there. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 440
