How do you replace an air fuel sensor on a 2000 RX300
I have been told that bank 2, sensor 1 needs to be replaced. Can I do this repair myself? How much will it cost for a mechanic to do the repair?
Yes it is a little hard to get to but it is possible. You can buy a sensor on ebay for less than $25.00. Auto part stores will charge $79.00 and up. You will need a drop light and a piece of cardboard or rug to lie on. You need to look up a where your exhaust pipe comes down. It is there. First you must disconnect the plug in behind the manifold then you can down below and unscrew the sensor. Just do the opposite for installation. I hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,272
