メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
Screen popped out on the top right corner
I just noticed that my 5C's screen popped out of the plastic chassis on the top right corner. The phone was put in an Otter Box by the salesman the day I bought it and it was never dropped seriously (from my lap on a carpet once or twice, but no more than that).
I've read somewhere that putting it on a flat surface and pressing on the back until it clicks back into place might work, but I'm scared it could break something, especially if it's battery problem (like some macbooks I've seen)
What do you think?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 12
1件のコメント
To be honest you should let any person you know is good with devices in your family look. or just go to apple. They could def help. Sorry for the advice. Its def not my best thing.
さんによる
コメントを追加
21件の回答
ベストアンサー
Do not click back into place have had people do that and break screens then come to me looking new ones..
The screen needs opened up and screen placed back in frame correctly
このアンサーは役に立ちましたか?
スコア 6
4 件のコメント:
I cracked my screen a couple weeks ago and got it fixed...a couple days later (after I got it fixed) I have noticed that the screen seems loose or something and the corner is starting to pop out
さんによる
thank you soooo much..its really helpfull.. it working..wven scae for to push it to hard ...tahnks again :)
さんによる
So a couple months ago I dropped my iPhone 5c and after that the screen would every now and then pop out.And I would pop it back in this worked for me all the time and I never had a problem.
Until two days ago the right top corner of the screen popped out a lot and it scared me so I poped it back in, un panic, and all of a sudden colorful lines are on my screen horizontal, and vertical, and it has colorful squares too!!!and the phone is clicking on things on its own! I swear it's going haywire! Is it able to be fixed!!?? Please help me I just want to be sure it can be fixed so I can get it fixed I have important stuff on it
さんによる
yo this ish worked in two seconds. i reccomend hard wood floor. game changing thanks for thisthread every1
さんによる
コメントを追加
I did my research on this and stumble upon this forum where they suggest to press hard the back of the phone on a flat surface which I did without hesitation and presto! it worked! my phone working fine as if nothing has happened to it.
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
Hi Trish, you got lucky. Sometimes this is due to a swelling of the battery. Pushing back will break the screen. Pushing things back when doing iPhones repair is the first thing I learned NEVER to do. Everything should fit in place. In this particular case, screen should be lifted, iPhone examined, then if nothing suspect is detected, screen can be fitted back. It takes 2 minutes and poses no risk.
さんによる
How should I lift the screen?
さんによる
Hi Shania, follow this guide to learn how to lift/remove the screen of the iPhone 5C. It also has links to the needed tools. If you reach Step 9, be extra careful with the position of those screws. On some iPhone models, mixing those up can kill your iPhone! This guide basically applies to iPhones 5, 5C, 6, 6+. iPhone 5S is a bit different because of the Home Button flat cable that you must watch out for when lifting the screen. You can find a separate guide for each of those models if you browse iFixit repair guides.
さんによる
I dropped my iPhone 5C from about a four foot height by accident and the top left corner of my screen popped out, it was still working but the screen would not go back in. I read several different sites and most said put against a flat screen and push until you hear a click, however some said don't do it as it might break but I took the chance and CLICK it was fixed. No need for a £50+ repair result!! #TAKE A CHANCE
さんによる
My iPhone SE was having the same issue, the right corner seems to be pooped out. I read the advice on pushing it back in on a flat surface, and it worked! the screen is back in its place and it seems as if nothing had happened. Screw the 50 dollar fix at the apple store.
さんによる
コメントを追加
Today I drop my iPhone 5c on the stairs and the top right corner of the screen starting to pop out. So I pressed on it with my thumbs and now it's perfectly fine!! It's still works great and nothing is wrong with it..
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
See we understand how this works for you, but just like Blaise Bernier, the person who asked this question, my phone was not dropped but suddenly has the screen popping out. This is because of the battery swelling up and needing extra space. This extra space was taken from the screen, therefore the popping out. If Blaise or I were to attempt to pop the screen back, there would be no space for it to go, therefore the screen breaking. So you must understand that your problem and Blaise Bernier´s problems are different, and that his problem is a lot more complicated and must be taken to the proffesionals, not be ¨popped back.¨
さんによる
コメントを追加
This happened to me today I put my phone on flat surface pressed hard and click! It worked! Yay!!!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
it should pop back in, however i have seen ones that went in for a screen repair before and a rogue loose screw (usually the long one for the LCD shield) would have worked its way out and into a crevice at the top right corner, thus preventing it pushing back in. There is a chance that by putting pressure on it that it may crack but usually they are fine .
i always open them up first to check but i understand everyone can not do that
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had the same problem I didn't know how it happened so I read some comments to press hard down and it worked.trust me
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I tried that but it wasn't working to I put tape on it so it wouldn't pop out more and my case kept it in place till I got it fixed
さんによる
コメントを追加
Hey guys,
Yesterday I had dropped my iPhone 6 in concrete floor so hard with strong bumper case around the mobile. Bumper case had protected my iPhone by observing all the major impacts though side of the screen has popped out little. I just pushed it back softly. Now my iPhone is working fine without any issues or heat.
It was very little pop out so without second though pushed it back.
Others pls be careful depending on the situation you come across.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
that's what happened to mine, but now i'm scared to drop it ever again in case it happens again and gets worse
さんによる
yeah, better use any strong protection case if u dont want to spend further for your mobile.
さんによる
コメントを追加
The battery is inflating because u are maybe charging it to much that is why it's only in that one spot
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you would attempt to push on the screen to get in back into place, you are risking cracking the screen or even breaking the clips that hold the screen to the frame. It is best if you remove the two screws flanking each side of the lightning port and open the phone up and PROPERLY seat the screen as it originally was. Also take some time to ensure the battery has not expanded. Hope it helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi my iPhone did the same thing tonight I was so mad for about 4 hours and then I was like push what do I have to loose so I flipped my phone over held bother my hands and squeezed as hard as I could ad. It popped back into place
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It might be because of swelling of battery,whatever, Apply some super-sticky adhesive in market and stick it,Be careful while applying..Make sure you use only a tiny drop.
This did the job for me.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I wouldn't do that because it might. Get bigger and the adhesive will come off
さんによる
コメントを追加
I had my screen repaired due to dropping it in a mop bucket and I took it to be repaired at the phone shop and ever since my screen has been popping up and I just don't want it to break? What shall I do?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Go to a phone repair place to get your battery replaced your battery is inflating
さんによる
コメントを追加
Just did what is said here - put on the flat surface on a len's cloth, and pressed hard, it clicked back to the case. Thanks a lot. - Yun
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i dropped my iphone 5s and the top left corner popped out but it popped back into place just fine. should i be worried it will happen again??
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the 5c's chassis is quite flexible so it should pop back in fine, all other models require you to remove the screen and re seat it properly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Dropped phone and upper left screen came out of the case (not Otter Box) and I took the suggestion of putting it on a dish cloth (face down) and pressed on it and it snapped back in to place...no problems!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
On the left bottom corner of my Samsung galaxy s5 is popping out. Everytime I like press down on it you can hear a click what do I do?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi I dropped my iPhone 5c (back down) on the hard floor and thought it was fine until I realised the left hand corner had popped out . I've heard that popping it back in has worked for a lot of people but I'm not sure weather I should just go to my local phone repair shop and get them to do it properly ,for free . However until then my screen is at risk of getting damaged because its sticking out . What do I do ?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Put it against a flat surface and push until it clicks in. It works a treat
さんによる
コメントを追加
Mine has done a similar thing except i have white stripes on the right side of my screen and ive lost touch across the whole screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, my iPhone 5c screen has popped out from throwing it around and I don't think pushing it back in is going to work. But I really not that concerned for my phone still works. I just pushed my phone screen back in it made a nice click and it works!!! So stuff you expensive repairs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If your battery is good just put your phone on the desk the back facing u and just push. It will click and work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Blaise Bernier さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 92
今までの合計 105,555
