メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
締切られた回答
When I move the pointer the whole display moves around and misbehaves?
The display moves around just as you would move around a web page on a smartphone or tablet with your finger. The whole display moves around when I move my finger around on the trackboard of the Mac Book.
I was think about replacing the display data cable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I don't think it could be the display cable if the display is presenting a good picture. I would look more into the trackpad. Maybe restarting the computer to reset things. or if the trackpad is getting stuck causing the computer to think you are selecting something.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Just to double check, I went into the system preferences and went into trackpad settings, and sure enough it had been set to move the image with the track pad. The screen is back to normal, but the image wont fit the display like the zoom is on, but I have it on the lowest size: 1280×800....any suggestions?
さんによる
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 58
