メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Responding Slow when opening an application
There is this day I was installing the Logos software, since I have a slow internet connection, I left the computer downloading the software the whole night. In the morning, I found the Logos was completely installed. However, the computer started running very slow. When you click anything, it will take 15 to 20 seconds and at a time more than that to open.
I upgraded to Yosemite, and it still does the same thing. I upgraded the RAM from 8Gb to 16Gb, it still does the same thing. Unfortunately, I took it to Office Max for diagnosis, they failed and I got it back, my MacBook Pro no longer have the operating system. Am trying to load OX Leopard I have, it is not responding.
Is any suggestion out there?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Computer slowdowns can be traced back to either Hardware (failing drives) or software (corrupt flew) as sources.
Often strange behavior can be solved by deleting the User/Library/Preferences/ .plist file(s) with the applications name in it. Cache files from the same location could be corrupt. That the files took a long time to download might be a checksum error (corrupt files again).
Corrupt fonts and not enough free space or fragmented HDs can also cause freezing, lagging or slowness.
Adding a new peripheral or having peripherals connected can slow computers.
Sometimes creating a new user account will expunge the corrupt files… in which case extreme care and time in moving back a few "must have" files from the bad account at time may point out the culprit.
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rodgers さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 229
