メインコンテンツにスキップ
A 17.3” gaming laptop by Asus with an Intel 3rd generation Core i7 processor, dual-fan cooling mechanism, and Nvidia 3D LightBoost technology.
10回答 すべてを表示
締切られた回答
Laptop not charging after falling on the DC power jack side
I have an Asus G75VX laptop and while it was plugged in my dog ran by and grabbed the cord causing the laptop to fall on the power jack side.
The side bezel is kind of pushed in and cracked around where the power adapter plugs into the computer.
When I plug the adapter into the power jack it does not charge.
What options do I have to try and get this fixed?
I don't know if it's the internal DC power jack or if it's because the bezel is broken and the power adapter plug is not reaching in all the way.
I was looking online for a guide to try and take the laptop apart or any suggestions and I couldn't find anything.
Any help on this topic would be much appreciated!!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi Daniel
It sounds like a solder joint could have broken loose or something inside the charger itself. This particular laptop looks to have a charge port soldered to the board, so unfortunately you cannot just swap a flex. If you do not have any soldering experience or do not want to attempt the repair yourself, I would consult a local computer repair shop and inquire as to their soldering experience. Good luck!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you Eric. I will definitely look into that
さんによる
コメントを追加
Protect your mobile phone charger & earphone cords from twists, tangles, knots and splits with a funky Spiral Cord Protector.
Stand out from the crowd by combining several different colours and give your charger and earphone cords a completely different look.
Each Spiral Cord Protector is 45cm MINIMUM LENGTH and availability from our eBay listings and our dedicated website:
http://www.spiralcordprotector.co.uk
http://instagram.com/spiral_cord_protect...
http://www.ebay.co.uk/itm/231418898626
http://www.ebay.co.uk/itm/231418898849
http://www.ebay.co.uk/itm/231418898756
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Look this service guide, i hope usefull:
http://www.myfixguide.com/manual/asus-g7...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,232
