メインコンテンツにスキップ
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
798回答 すべてを表示
When I plug it in, get apple logo and sad face
The iPod won't turn on, when I plug it in, it says the battery is extremely low then after a while it comes on but only goes to the apple logo, then to the sad mac then back to the apple logo then to the extremely low screen etc.
I was told by the folks at the apple store that it was a bad HD because I ran with it. I replaced the HD and the battery but I still have the same problem.
I was apple to sync it once before I replaced everything. It worked, but the next day, it said the battery was extremely low. I let it charge overnight, no change
Is it time for a new logic board? I replaced everything else.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Here's Apples answer to your sad face: http://support.apple.com/kb/HT1378
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
When I plug the iPdod into my computer the apple logo comes up and stays up. I can't go into disk mode, but it will reset if I hold down the menu and select buttons.
さんによる
コメントを追加
回答を追加する
craigbrowning さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 2,641
