メインコンテンツにスキップ
Runs only off of AC power. Can you really fix it?
I recently replaced the hard drive in my iBook and now it will not charge the battery. I replaced the battery connector what could it be? I click on the battery and it says battery not charging. I ran the coconut battery thing and it says
Charger connected
Battery not charging
Current Battery Capacity is at 82%
It is an aftermarket battery and charger.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
With Coconut stating the battery as good, it probably is. I would see if it will run on battery power alone. If not then I would have to suspect the battery connector, either the part or its connectors. The main suspect would be the battery transfer board, Apple part #922-6183 as seen in the lower left of this diagram: http://ep.yimg.com/ca/I/loveMacs_2112_38...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The poster has already replaced the battery connector though.
さんによる
コメントを追加
Test the battery in another computer- if it does not work, get a new battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Colby A さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 595
