Dryer has a burning smell
My dryer has a burning smell that transfers to the clothes. Is there a way to open it up and clean it out. I have taken our the dryer link screen and cleaned out lint from the inside area also.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The smell is actually lint within the body of the dryer that has caught on fire. Please clean your dryer out immediately!!! I have had the same problem. Remove the front panel below the dryer door ( two bolts on the very bottom, one on each side), and give it a good cleaning!
このアンサーは役に立ちましたか?
I know this is %#*@ near 5 years old but this comment just saved me from a house fire. Removed the front panel at the bottom via the two bolts you mentioned and BAM! Just handful after handful of scorched lint. We just bought this house a couple months ago so I guess the previous owners didn't do $@$* for maintenance. Glad I caught it early. Thank you!!!
過去 24時間: 2
過去 7 日: 12
過去 30 日: 43
今までの合計 6,712
2 件のコメント
Hi did you ever figure out the problem with your dryer? I'm having a similar issue.
Kindest regards,
Kvn
Kevin Propper さんによる
looking to fix this smell it is horrible makes the clothes smell terrible any help on this would be great . cleaned out all the lint replaced the heat sensor
What would be the next step
fortniangua さんによる
