メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
New screen replacement top left corner doesnt completely flush
I am currently having a hard time fixing an iPhone 5s usually i dont have a problem doing these screens. I have everything set but the top left has the light coming through a little bit and it will not flush like the other parts of the new screen. Help please this is for a customer and i tryed his old screen and it fits perfectly. is it the plastic hinges on top idk please help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
There are a few things that could be causing this, the most common being frame damage. Is the frame bent at all, any scuff marks near the area not sitting flush? The old screen could have similar damage allowing it to sit flush whereas a new screen would not have this damage, possibly causing it to not seat properly.
Another issue could be the quality of the replacement part. I've had parts where the frame would be lifting slightly, almost invisible to the naked eye and only noticeable after seating the screen. The side of the display frame can flex and catch on the side of the phone's metal frame. Another possibility is that the flex assembly for the front camera and proximity is loose and catching on something as well.
Last possibility I can think of without having it in front of me would be a part that was possibly manufactured outside of the proper specs. It happens a lot on copy grade parts, where the glass isn't cut exactly right or something similar.
So, in closing, check everything to make sure all components are on tight, nothing is falling apart during closing the screen, and lastly try another display assembly.
Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Richie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 2,484
