メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
iPhone 4S not turning on anymore
My iPhone 4S is not turning on anymore, even when plugged into a wall charger.
It is not showing the apple logo and the battery is not even getting warm.
After using another logicboard it booted just fine without any problems.
What do you guys think is the problem with the logicboard?
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
What is the voltage on your battery connector when you plug it in? Check if there is continuity between the - and + on your battery connector.
さんによる
My connector was giving me 0 volts, so I looked at the schematics and after a while noticed the wifi chip had a short.
After replacing thhe chip my iPhone was starting up, but R49_RF and C13_RF are missing, and my U5 was getting veeeery hot, with the batteryconnector reading 4,05volts.
But after 1 day it would not become hot anymore and booted normally, but now the wifi is greyed out.
Has it something to do with R49_RF and C13_RF missing?
さんによる
コメントを追加
2件の回答
最も参考になった回答
I would honestly drop it in an ultra sonic cleaner and then try it again. Or go to a shop and get liquid damage treatment.
Try It.
Also where do you live. If its in the SE of the USA defiantly try it. Good Luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Well if you used another logic board in the same frame with all the same parts and it fired up and other logicboard dosent then it's definatly a fault with it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah I tought that too.
But is there a way to find out where exactly the logicboard is damaged, because I am able to to micro-soldering, so maybe I can fix it.
I only don't know how and where to search
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 624
