メインコンテンツにスキップ
Repair and disassembly guides for Kenmore Microwaves.
How to access vent light button assembly to reattach button assembly?
I have a kenmore elite microwave hood combination model 790.8037. Vent and light button assembly detached from front of microwave. The button assembly fell behind the face of the appliance. How can I take face of microwave off so I can reattach to face?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント:
I have same problem. My microwave model 790.80362310
さんによる
コメントを追加
3件の回答
Were you ever able to fix this? Our vent light button assembly just fell in. I haven't had luck finding directions for taking apart the front face or buying replacement parts. As best I can tell, Sears recommends buying and replacing the entire control panel assembly (Part #: 5304491493 $263, plus labor).
http://www.searspartsdirect.com/model-nu...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just unscrew the bottom of the hood and take it off. You can the reach behind where the buttons are and tape them back on or glue them.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I removed bottom of the hood but still can't access the vent and light button to reattach.
さんによる
You should be able to see the buttons inside. You will have to glue them back with super glue.
さんによる
I did end up fixing it with super glue. Had to slide the whole panel up and pop it out so I could get underneath and re-attach the button assembly.
さんによる
Hello could you describe what you mean by slide the panle up
I am working on it now
さんによる
コメントを追加
Thank you for this useful post.
From the image of the panel on Sear’s parts page (OP’s link) you can see the location of the one screw that holds the panel in place. The panel has tabs that slide in then down. To get to that screw remove the vent/filter trim piece on the top. The one screw keeps it from being bumped up and off. Beware of the wires. There’s not much room to work. I took the bottom trim off but maybe that wasn’t necessary. I’m trying super-glue in three points. Looks like original installation was glue on the heads of three screws then pressed into place. If my effort at super-glue fails I’ll try using a small block of wood behind the switch plate to wedge it in.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
This just happened to our microwave yesterday. Thanks for this info. Will try this fix today.
さんによる
Judie Silver, were you able to fix it? I'm confused if I take off the panel on the bottom or the panel on top. It's very awkward to work over the stove.
さんによる
I fixed my Kenmore convection oven/microwave #80373. Through the "top" method, Do not remove the bottom trim. Super glued the 3 points, and a touch of duct tape on edges of circuit board to secure it in place against the plastic frame. Works beautifully! Thank you everyone!
さんによる
Okay, I'm doing this now and here are the steps.
1. Unplug the microwave as you will be accessing electronic areas
2. Open the mircrowave door, remove the upper vent guard to reveal the 1 screw holding the control panel in place.
3. Remove the screw, grab control panel and slide it up and then pull out to reveal inside
4. Disconnect wiring if desired (take a picture) but remember what wire when where. Or, just work in the space provided leaving the wires attached.
5. Fix the buttons as needed (glue, wood, etc.)
6. Reattach the wiring if you detached anything, put the control panel on and slide down.
7. Reattach the holding screw and vent cover.
さんによる
Glueing did not work. Were you successful using wood?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
David Hadley さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 72
今までの合計 6,328
