メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
締切られた回答
Not booting after attempted screen repair
The iPhone 5c I attempted a screen repair. I did not unplug the battery and it was on so I could quickly see if the screen had any issues. I plugged it in and nothing came on while I was diagnosing the problem (I had flickering).
I then thought that the issue was the screen had died, so I tried the original screen. It did not work as well. I panicked, and plugged it into the computer, but it does not recognize it at all.
Did I short it out? Is there any way for me to fix it if so?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
So you could quickly see? it literally takes 30 seconds to boot up. Connect the screen and everything back up and then disconnect and reconnect the battery, see if that works
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This worked. Thank you. I guess I hit a fuse. I have a problem with white and not black so I wanted to do it quickly. I will be more careful now. I never had problems with safety before so I ignored it and it caused me this problem. Thank you so much
さんによる
コメントを追加
最も参考になった回答
You left the phone on so you could quickly see??
That really is not a smart thing to do
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yeah, I need to be more careful from now on. I was tired and wanted to finish it fast and it cost me more time and paranoia.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 93
