メインコンテンツにスキップ
MacBook、MacBook Pro、MacBook Air用のAC電源アダプタです。引っ張られても安全に外れる整列式の磁気コネクタを採用しています。第一世代 (2006-2012)のMagSafe充電器は、コネクタがやや太いL字型になっています。45W、60W、85Wの3種類があります。
Not charging, blinking green/orange light
My magsafe power adapter is not charging my mac (MacBook Pro 13" mid 2012) black screen, no battery no power up.
Happened over night, worked fine yestreday.
No green light on the adapter plug, only blinking between green and orange. what does that mean?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 16
5 件のコメント
If the SMC reset won’t work, the problem is that the charger doesn’t fuse enough bolts and energy. Plug the charger somewhere else in your house.
さんによる
The charger is working perfectly when the MacBook Pro is shutdown. it charge continusly. when the MacBook Pros in switched on that time it works for 30 seconds by indicating orange LED and then show for 5-10 seconds Green LED and then keep swaping Orange and green LED and it charge but slowly.
I think this will damage the battery in future.
I have already tried the upgarding MacOS, reset SMC, Resert PRAM but no success.
I tried using another charger with same MacBook Pro it works perfectly.
さんによる
My problem isn’t the battery is a AC charger which isn’t working as usual. It’s only blinking when I charge it but my computer doesn’t charge during that moment. So how should I proceed
さんによる
my hp compaq 6710b has dust so i open it and cleaned it also i closed it after cleaning but its not powering up its just blinking in the power light in green for long and the thunder charging light in orange what can i do to make it power agaian please.
さんによる
My MagSafe power cable suddenly stopped charging MacBook Pro. It has faint green blinking light at the connecting point instead of green visible light. Anyone can help me to find out whether I need to change power cable
さんによる
コメントを追加
14件の回答
ベストアンサー
Try an SMC reset. If that changes nothing then you have a hardware issue could be the charger, the DC-in port or the battery is bad.
Replacing the charger would be the easiest cheapest place to begin.
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 10
9 件のコメント:
Thanks. :-) It worked, I just unplugged the battery for few seconds and everything works fine now.
Good times. :)
さんによる
I have the same problem with my Mac (MacBook Pro 13" Late 2011) but in my case the problem was not solved this way.
My MacBook only charges when is off or in suspension mode, so i unplugged the battery and it works normally with no battery. But when I plug the battery again the problem persist (Only charges when is off or in suspension mode).
My battery has 958 cycles.
さんによる
I have the same problem, it charging, but blinking green/orange light
さんによる
In my case, my battery is bad! I changed and everything works fine now
さんによる
Unplugging the battery and reconnect it, worked for me!
さんによる
4件以上のコメントを表示
コメントを追加
disconnect the battery charge indicator from the motherboard. It is near the battery connector. This should solve your problem
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
how do u do that?
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi,
try closing the process called 'usbd' using the activity monitor (OSX)
it helped me
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
In my case, when I connect charger green light shows even battery status shown 1% and its stucked on same percentage. Plesse advise me what can be done to fix this issue.
さんによる
Quitting USBD topped the blinking, the 2012 MB Pro is charging again. THANK YOU! This is my back up MB Pro. My main machine won't start at all as of yesterday, no lights on MagSafe at all. (Which is why I went to BU machine.) But, at least I have ONE functioning laptop... Now to the main mystery...
さんによる
コメントを追加
I had the blinking light yesterday.
I opened may MB 2011 17” and it was hot as !&&*. I took off the battery and waited. 12 hours later it was working as usual.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Glad I found this page and that the fix was something easy! I can't disconnect the battery on mine because it's soldered on for my model, so I'm really hoping that it's the charge. It started happening out of the blue, so I ran Apple Hardware Test, reset the PRAM and SMC, and tried a different wall outlet. I'm really hoping it's the charger and not a hardware failure, but I think it's software related because it gets way more intense if I can get it to log in.
I have the retina 15" with the touch bar and the last time something stopped working I ended up needing the motherboard replaced since you can't remove parts on the new ones... It was a $750 to just repair it, after I'd already invested around $2999 init initially.
I'm hoping/praying this issue is my charger/stops so I'll be able to charge it, or I'm gonna lose my mind! (And all my money)
EDIT: Finally got it working! Must've had something to do with the USB-C devices or something, but I took it off the MacBook charger and plugged my Nintendo switch charger to see if that'd work (the new ones only have USB-C ports), and after plugging that in I plugged the regular charger back in and it started right up like nothing had gone wrong! Not sure what the !&&* happened haha
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
In my case when i plug charger nothing happen, no green light and no orrange light. But when I unplug charger “battery status” lights (green) start blinking.
I just clean my charging port and charger pin with tooth brush.
It works for me. Mac start charging.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is doing longer loops of Green-Orange-Off now.. :{
さんによる
コメントを追加
what does it mean when the magsafe 2 adapter is blinking amber and green and still charging
also the upper right of the keyboard is getting hot.
I got a MacBook Pro 13-inch (early 2015)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey i am facing the same issue. Did you get any solution for that??
さんによる
コメントを追加
Mid 2012, 15" - i7 - MacBook Pro here
I had the blinking light on my power brick. I unplugged it from the wall and the thing just kept blinking and alternating between amber and green... even though it was unplugged.. and this went on for about a minute.
After the light show stopped, I plugged back in, and BOOM... fixed
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I took apart the backing tried to take out the battery but this model has it soldered so I cleaned the terminals where the magsafe ports are. It looked like there was a bit of residue on the mother board so I scraped some of it off with the toothbrush and voila. I plugged it in and the fan began to whirr.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine is a mid 2012 13” MBP,
It's not powering on, not charging properly, not showing anything on battery indicator. Though battery was absolutely fine the last time I used it.
The charging led is just showing faint green light, when I try SMC reset, it just keeps blinking faintly. I've tried cleaning the ports, removing the battery connector for a few minutes. I took it to Apple service centre and even their charger didn't work.
Can anybody help with this?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same happening with me...can u help?
さんによる
コメントを追加
Mine is a mid 2012 mac book pro when I plug in my charger it changes inbetween green and orange and my battery icon glows bright red with a “service battery” condition …how do I solve it pls
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
what part of "service battery" you don't understand? :)
さんによる
コメントを追加
Mine just flickers between green and nothing when my computer is on, and when shut down it flickers between being green orange and nothing.
I tried a few things and eventually figured it was my charger than needed to be witched out with a new, luckily nothing wrong with my laptop!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
telango さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 63
過去 30 日: 299
今までの合計 333,971
