メインコンテンツにスキップ
2012年11月2日に発売されたiPadの第四世代です。Wi-Fi, CDMAもしくはGSM モデルがあり、16、32、64GBの容量オプションがあります。
Main Camera not working but works with FaceTime.
OK this is a strange one.
I have an iPad 4 wifi +3G which i'm refurbing.
I have transferred the Motherboard battery & other parts across to a different casing which is in excellent condition.
The casing from original was pretty beat up & very badly damaged in one of the corners but everything on it worked fine including both camera's.
This is something i have done many times before without any issues so i'm not someone who is attempting this for the first time.
Everything is working fine except for the main camera when i try to use the camera app it just stays black & i can't switch cameras to the front facing one.
Also i cannot get a camera to work with photo booth BUT both camera's work fine when using FaceTime !!!!???
I have tried different headphone jack logic boards both brand new & from known working iPads I've also tried different camera's again new & from working iPads yes they work fine when put back into the iPads they came from.
I have DFU restored & updated to IOS 8.1.1.
Any ideas guys any help or suggestions greatly appreciated.
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント:
i have exactly the same issue, did you sort it? what was it?
さんによる
コメントを追加
1 件の回答
Same thing happened after taking iPad to store to fix jammed earphone jack!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kenny Leonard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,102
