メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2397回答 すべてを表示
How to activate an iPhone 4, which wont read sim card?
The phone started out by now being able to register if there was a sim card inserted. It simply said "no network".
I though it might be software issue, and triede reseting the network settings. This got the phone stuck on boot.
After several attempts i got to the activation screen, trough recovery mode.
But now the phone cannot activate as it cannot read the Sim card. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
Which company is the iPhone 4 from? Also, which company is your SIM from? Is the SIM active?
If the iphone is from the same company as the SIM and the SIM is active, then try this:
Remove the SIM card from the phone.
Reboot the phone.
Make sure it says "Insert SIM" at the top left of screen
Insert the SIM card
Verify that is says "Searching" at the top left of screen.
What happens now?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I am unsure, as it is a phone that i was to help my friend with. The sim is from a european provider, but it is unlocked and i have activated other phones with it before.
It never gets to the 'insert sim', but is just searching. (could this be because I had the battery removed previously perhaps?)
It wont register when i remove/insert simtray with or without a sim
さんによる
コメントを追加
Yes, removing the battery while the iphone is powered on can cause this issue. It may take some playing around with to get it to detect the SIM again but the general idea is to try to get the "Activation" screen to come up.
You can try a different SIM
You can try to go to the reset menu and either reset ALL SETTINGS, or reset network settings. Do this with the SIM in. If that doesnt work try doing it without the SIM in. Only insert the sim after you see the "No SIM" message.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iphone emerginsg call lock or unlock any idia
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sonnicham さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,840
