メインコンテンツにスキップ
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136回答 すべてを表示
My tab WONT TURN ON need help
so i was using my LTE samsung galaxy tab 4 7.0 this after noon its like brand new I've had it since october mid way trough so its less than two months and i pressed the button for the screen to go dark not off just to sleep and feel asleep i woke up about an hour later and it wouldnt turn on it was at 50% so it was fine for the rest of the day and i only had 2 applications running which is not a lot compared to what i normal have, like they weren't open they were just there in the back round and now it wont turn on and I'm using it as my phone so i don't have a phone now ether i don't know what to do I've tried pressing all the buttons and holding them down i plugged it in to the charger and it didn't even show that it was plugged in its not over heated and when i plug it in it doesn't over heat what should i do if it doesn't work in the next couple of days it will go back to the store where i brought it from but its in singapore so I'm trying every thing i can to fix it here so it doesn't have to make that trip :/
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
Mine is the same way but no water damage or never been dropped
さんによる
Read this article to get rad of your problem https://www.getthetechnow.com/2020/05/ho...
さんによる
コメントを追加
1 件の回答
ベストアンサー
Have you tried a hard reset ?
http://www.technipages.com/galaxy-tab-4-...
May help, good luck
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
jasmin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 2,563
