Setting the Alarm?
I just purchased this alarm clock and there was no owner's manual included in the box. How do I set the alarm?
Traditional analog twin bell alarm clock by LaCrosse. 6.5 inches in length, 4.5 inches in width, and 2 inches in depth and 8 ounces in weight. Gold metal case, luminous hands and hour dots, analog quartz movement, and clear glass lens.
That's too bad that your clock did not include an owner's manual. It can be found on the manufacturer's website by following this link:
http://www.clockworks.com/clock-movement...
*Note: The model number on the owner's manual is stated as model #13012, but the same directions apply for model #13014.
Follow these directions on how to properly set the alarm:
Locate alarm set knob above the battery compartment. This is located on right side of time set knob. Turn alarm set knob in direction of arrow indicator to desired alarm time.
Make sure that alarm hand has been set to appropriate alarm wake time. Turn alarm ON by sliding alarm switch on back of alarm clock to ON position which is indicated by the picture of the bell.
Good luck!
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 214
