メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
No Display backlight on the 2010 MBP 15. Options?
Hi!
I got this computer from a friend and he claims the backlight doesn't work. I tested this out to be true by
1) Booting the computer to external display. Works alright
2) Shining a light to the display shows stuff = Data is sent to the display, but backlight doesn't work
I tried cleaning LVDS cable connector on the board and LVDS cable itself but to no avail.
So what could I do? I'm guessing that the LVDS cable could be at fault but also the backlight controller on the board, but I can't for the life of me locate it or find some info on the internet. I could only find where's it's located on the 2009,2011 and 2012 computers but not on the 2010 ones
Here's a picture of the board
By the way. The guy is a heavy smoker, and I found a lot of yellow and orange dust inside the fans. It could also damage the components, maybe
Thanks for any help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What number is your logic board? Should be starting with 820-xxxx and be on the board itself. You will also have post images of both sides of the board.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Marhowl, I'd start by checking the fuse for continuity. Let us know what you find
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
I got to get my hands on some multimeter, since I don't have one.
In any case, thanks for showing me the location.
Could it be this component? http://www.ti.com/product/LP8550/datashe...
さんによる
Yes it could be. I will get you the proper info in a few hrs. did you get the numbers I requested in the comments? that way I can make sure it is exactly what you need.
さんによる
I have found this number on the LB
Apple 2010 820-2850-A
Do you still wan't the pictures? I have found the piece to be called LP8545SQ from Texas instruments btw =)
さんによる
No images needed unless you need to further identify any components,. The LED driver is indeed a LP8545SQX. Great job...
さんによる
Alright. So what now? Should I check for continuity on the components and get back to you? Could take a while. I'm a newbie without multimeter =/
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Marhowl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,367
