メインコンテンツにスキップ
Xbox 360ラインの2013年中期に発売されたゲームコンソールです。4USB端子と組み込み式Wi-Fi接続が特長です。
89回答 すべてを表示
does removing the hard drive break the warranty seal?
My xbox 360 e 4gb edition gave me the red dot of death after having it and normal use for about 10 months and im trying to fix that and everyone keeps telling me to remove the hard drive and vacuum the outside and I want to do all of that. But I also want to use it to trade in for an xbox one but I cant break the warranty seal so im just wondering if opening that will break the warranry seal or not?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Or if someone has any ideas on ways to get rid of the dot of death for me that would be greatly appreciated!!!!
さんによる
コメントを追加
2件の回答
最も参考になった回答
Removing the hard drive is very simple, just look on the side and look for the slide release for the cover, then pull out the hard drive. This will not break the warranty seal in any way. I wouldn't try to vaccum out anything with a household vac, what they are talking about is removing the case and getting rid of dust inside the unit, might be causing over heating. Removing the case will break the seal and void the warranty, but if you 5hink you might have excess dust inside then and you've had it more than a year you would have a warranty anymore anyway, but use compressed air, like the kind used for keyboards, to blow away the dust.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yes opening and removing the internal memory of a 360 will void the warranty only if the memory is located inside the 360. If it's the model with an external hard drive then you will not void said warranty.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dalton Pachano さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 612
