メインコンテンツにスキップ
2012年3月に発売されたオリジナルiPad2の改良版モデルです。より小さくなったダイプロセッサと再デザインされた内部構造が特長です。修理にはヒート(熱)を当てて、十分注意しながらこじ開けて行く作業が必須です。
power button and volume buttons do not work
I have replaced the power flex cable and it still does not work. I saw another post that said it could be a bad control board so i replaced that. Still does not work. The cameras both work but the power and volume buttons do not work. Am I missing something?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
If your cable is properly seated, and you did not damage it during installation, then the h next thing that comes to mind and that you need to rule out it is the possibility that you have a defective cable; you'll need to try a new one.
Once you receive a new one from a different supplier if possible, test it before installing it: unplug the old cable, plug the new one instead, and carefully press/test the buttons. If it works, then remove the old one and install the new one. Don't go cheap with those cables. Choose the best quality you can get because they are such a pain to replace and you don't want to have to constantly replace defective parts. First because of the time you'll be wasting; second, because there is an inherent risk to every repair attempt, so you don't want to test your luck indefinitely. I recommend buying the iFixit cable because they usually carry the best possible quality and stand behind their product with a good warranty.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Make sure that ALL the connections and ports are screwed-in/connected securely. That should fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeff Halstead さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 504
