メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
Shows charge symbol but it is not charging, any ideas?
I am a smartphone and tablet repair technician so I have done close to a hundred iphone 4 and 4s. This 4s need the charge port flex replace because it wasn't charging. After the replacement was done, I plugged in the charge cord and the phone got stuck in a boot loop. After troubleshooting it for a few minutes I decided to change the charge port again. Installed a new one and this time when I plugged the cord in the phone booted up fine. I let it sit on the charge for a few minutes while I did other repairs. When I came back to the phone I notice that the battery percentage did not go up at all, so I place a new battery in and repeat the charge process. Wher I return to it again, same problem, battery percentage did not increase it actually lowered a percent. The charge symbol is displayed but not charging. Since that I have tried 2 new batteries, 3 different cords and chargers, home+wake/sleep restart, and put it into restore mode (cancelled that before actually restoring) so I am stuck.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
4件の回答
Are the cords that you used original Apple cords?
Otherwise I think your USB chip is dead, if you had alteady used multiple batteries and ports
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When the phone is plugged into charger and it indicates that it's charging hold power button and turn off now leave 30 minutes and come back and turn on and see if it has charged battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same problem here on my 4S - I've replaced the battery and used different cables but no joy. Says it's charging but it isn't.
Can i replace the USB chip?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
icon shows but charge hang 3% after long time,next time put change but same problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt man さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 9,431
